a little help with big project??
I am currently tearing the truck apart to install a lbz cp3, remove the EGR system completely, and add a little extra airflow:cool2: there are a bunch of little fuel lines on top of the cp3 that are really hard to work with without just totally removing them...is it OK to reuse the copper washers? also, how the hell am i supposed to access the intake bridge bolts under the stock turbo mouthpiece? I cant take the mouthpiece off because one bolt can't come out without the intake bridge out?seems pretty f-ed up to me. i found that my thermostats were deteriorating, the inside of my upper coolant tube was flaking this hard black sh*t, it's nasty, and that wiring harness that goes across the top off the motor is hard to work around...looks a lot easier in the manuals (because it's not even mentioned). all in all, this motor is a PITA to work on, i can't wait to do it all again this winter. sorry for the venting, but this is supposed to be a 4-6 hr job (cp3) that has taken me 7 already and the old one ain't even out yet.
maybe this winter I'll have a friend of mine just re-machine the intake components to try to make tear down easier because this is rediculous.
