CP3 Fuel System question
brown bear
como estan beeches!!
Mar 31, 2009
199
Durango CO
i was thinking to get a CP3 for my truck im not sure witch itll be the best choice for my 02 lb7 and also i heard two diff things some say that is better also to get a bigger injectors and also someone else told me not to remplace them since its really hard to adjust them at the right point so im not sure what its true or whats the best thing to do any suggestions will help for sure thank you :hello:
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
The LBZ or LMM pump is a lot better than the LB7 and LLY pump. Not exactly sure why...
The LBZ/LMM pump can support a significantly higher demand for fuel if the tuning is using it. I don't know how much better the ATS or II pump will be. I would guess that they are lightly modified LBZ/LMM pumps. I know there are some pumps out there that are significantly better than the stock units though, I think lots of guys run the Wicked Diesel stroker CP3's
brown bear
Mar 31, 2009
199
Durango CO
nice good things to know so it seems that eather LBZ or LMM will work better for sure! so do you know if itll be any modifications that ill have to do to make it fit in my lb7?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
The lbz and lmm pumps have more displacement than the lly and lb7. If you have the money and are looking into a bigger modded single I would go with a wicked diesel unit hands down. Pat has tested them and they will outflow the other pumps.
brown bear
Mar 31, 2009
199
Durango CO
sweet i heard about this ones too i just did not know anybody who used them before would you recommend any place to get it some where around here? :)
paint94979
Beer Nazi
Sep 18, 2006
11,715
As far as I know Pat, and myself are the only ones who have actually ran them. I picked up almost 6 mph from switching to a WD CP3 from my stock LLY pump with LBZ Regulator.
