My BURB is starting to lose it's CP3. She can barely hold 155 rail pressure now with a 1800 PW, and is also getting to where hot she doesn't start as fast as she used to. The injectors have almost 15K on em and the balance rates are all good, and the regulator also only has 15K on it. I've decided to go with a new LBZ CP3 as I don't plan on going big with my tuning, I only want to hold a 170 MPA rail pressure with a 2200 PW or so. My main question is should I go with the stock LBZ regulator, port my LB7 regulator, or port the LBZ regulator? Like I said I have no p[lans of going big with my tune as my front end can't hold it in 4X4, and my 10.5" 14 bolt is the limiter out back.
