ok so I have a 03 lb7 low miles. I just drove the truck a week ago and it ran fine (other then my 2-3 shift is messing up again). went to go start the truck today and it wont engage the starter. All dash lights come on, gear indicator is working fine, it recognizes my key as driver1, I can communicate with the ecm and tcm and see data from the ecm, I pulled the codes and I will post a screen shot of the codes below only new codes are relating to ABS which seems odd because my ABS light is not on??
I do have power to the starter from the battery, I do not get any 12v+ to the solenoid coil when I go to turn the key. I jumpered the solenoid coil with 12v+ and It kicked the motor so it doesn't look like the starter or solenoid.
I checked all fuses and not just visually. I did flip flop some relays and no change...WTF
Any body got a wiring diagram I could use to help me eliminate more electrical...
any help appreciated
last code is for HVAC and second to last I tink was from me shuffling relays
