LB7: Cooling System Headache
Dirtymaxx03
3,109
I am about to pull my hair out.
So i thought the truck had blown head gaskets because the low coolant light would always come on and i was always missing coolant.
Well i replaced the thermostats and i think that fixed the missing coolant problem (was spewing out of the overflow i guess) however the light will still come on.
I can be driving for 20 minutes and the truck will not heat up at all, heater wont work, truck sounds like crap. Then all the sudden the temp gauge will shoot up to 180* and the truck sounds better but the heater wont blow hot.
Eventually the heater will start working but almost at the exact same time the heater starts blowing hot, the low coolant sign will come on the DIC.
I can stop the truck and turn it off and check the coolant and it will look real low, as soon as i pop the cap and relieve pressure, the coolant level will rise to where its supposed to be.
Its like the cooling system is over pressurizing itself or something.
HELP
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
HELP
gasket...... mine did the same thing when it went
Dirtymaxx03
3,109
well if the gasket took a shit, i figure i would be using coolant. But im not and thats what has me stumped. Im not keeping this truck much longer so if i tear into it to fix the gaskets and install studs, only to find it didnt need it, i'll be pissed
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Sounds like head gasket
System is pressurizing pushing coolant or not allowing it to flow correctly that's why you're seeing the spike in temperature then all of a sudden heat. You said that it was pushing coolant out of the overflow which means it is pressurizing so you must be loosing coolant.
Dirtymaxx03
3,109
It was pushing coolant out before the thermostat change. I could fill my truck up with coolant, dry off the area under the overflow spout, go for a hard drive and see where coolant had shot out of the overflow. Stopped doing that after thermostats changed.
i feel like if the headgaskets were blown, a 3100uS tune at 30* of timing would drain the coolant in a short time under WOT, but it doesnt
2001-GMC-LB7
01GMCDMAX
Jul 27, 2010
67
NWNJ
My 2001 ended up being injector cups (2) leaking, installed new head gaskets and rebuilt heads to fix it... You Know I also HAD to install ARP studs, rebuilt injectors, injector lines, Glow plugs, new water pump, new turbo (Bigger), bigger down pipe, rebuilt injection pump, all hoses, and pulleys, tensioner, belt, while I was at it...:D
Dirtymaxx03
3,109
Yeah I'm kinda stuck at a fork in the road here.
I could go drop 15-20k on top of what I sell this truck for and get a nice new stock truck that's quite and reliable.
Or
I drop some money into this truck
Carrilos
Cast ovals
Head and main studs
Key way work, etc
Nothing big. Hell I might just slap a set of rods in it and call it a day.
Who knows. All I know is I have lost feelings for my truck. She's not the same. It might be time we broke up lol
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
Or
Carrilos
Cast ovals
Head and main studs
Key way work, etc
Lml time :D
