LLY: Coolant Tube to Turbo Check Valve
valleyduramax
233
Ottawa ON Canada
Hey i am fabbing up a new coolant tube to reroute out of thermostat housing to in front/over AC compressor to rad instead of behind the AC compressor. Question is, the coolant feed line to the stock turbo housing has a check valve that appears to have constant but variable flow. Does anyone know of a replacement valve that i could install instead of the cumbersome stock one?? Or could i figure out the surface area of the stock one and just replicate that and add a second line with a low regulator or something? Maybe a long shot but gotta ask. Whole reason for doing this is to declutter and simplify hose routing and to be easier to fab up.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I believe it is a thermostat, and I have no idea about replacing them as the only time most are altered is when people take them off to put different chargers on.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Yep it's a t-stat. I believe it is around a 210-220 degree t-stat designed to cool the turbo down quicker, but not to run it to cool.
valleyduramax
233
Ottawa ON Canada
Is there a different setup that the vans run? They have the coolant line run in front of the motor as well i think?? Or the LML also has the same routing i thought? Any info on there setups would be great thanks
