LB7: Coolant leaking
UPF
Sep 7, 2014
I have coolant that leaked out yesterday after I turned the truck off. It appears to be coming from the drivers side up towards top of engine. Does not leak or drip while engine is running.
Coolant low light came on a few weeks ago and I added about a quart. Has not come back on since.
Any thoughts?
02greysixer
1,829
North Central FL
There are so many places coolant can leak. There's no way to tell without putting pressure on the system. But the water pump is on the divers front of the engine
UPF
Sep 7, 2014
Is there a weep hole? I did see that the coolant ran down a pipe that has small hose running along side it.
1,864
Use a flashlight and look up underneath the drivers side behind the P/S pump area at the waterpump. Its probably leaking there.
