is it common for the turbo to leak coolant? i had a truck dropped off and was diagnosing it for coolant loss i put a pressure tester on it today and started pumping it up and noticed it leaking from the heater core connectors, fixed that and took it for a test drive and got back and the inside of the exhaust was wet and smelled of coolant. egr has also been deleted so that would rule out coolant leaking from that. anything else it could be?
