coolant leak???
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
So I have a coolant leak coming from the drivers side behind the oil filter housing . It looks like it might be coming from where the coolant pipe that comes from the water pump connects to the engine, but I'm not 100% sure. It drips immediately on startup so I don't think it could be hg issue but anything is possible I suppose. Anyone else had this problem?
03BlkMax
Jul 15, 2012
125
Kentucky
Had the same issue on a buddys truck recently. Had to put new oil cooler gaskets on it. Merchant has a complete gasket kit for it.
Galaxy S3
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Galaxy S3
Thanks:hug: Luckily I was going to change the oil this weekend anyways so they'll be no waste there. What all had to be removed to change it and about how long did it take?
03BlkMax
Jul 15, 2012
125
Kentucky
His was a little easier bc he upgraded to the lml exhaust manifold at the same time. This gives you a ton of room to work. Without taking the manifold off its pretty tight but doable. It will prob take a couple hrs
Galaxy S3
