LB7: Coolant leak???
madmax02
Apr 30, 2012
88
Taylor, Mi
Well here's the situation, cooling system pumped to 15psi. Lost about 8 pounds in about 6 hours. Upon startup no smoke. NO visible leaks in engine bay with no sweet smell. Just got a call from oil analysis and they confirmed that there was coolant in the oil. When I changed it it was not milkie. No check engine lights hasn't been overheated.
What do you guys think?
5,813
find out what percentage. they should have that on hand or in your analysis.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Coolant in the oil without it going into the combustion chamber sure sounds like an injector cup O-ring spraying coolant in under the valve cover to me, but it could also be a head gasket leaking into one of the oil galley drains as well. Pull the valve covers and pressurize the system is where I would go next.
5,813
x2
madmax02
Apr 30, 2012
88
Taylor, Mi
So really best thing would be pull valve cover and pressurize the system again and see if I can find coolant sitting/leaking around an injector.
5,813
Yup. make sure your coolant is topped off and there is no air at the little bleed screw on top of the thermostats before you test.
