Question: Coolant leak on water pump supply tube
dh737
Jan 26, 2009
3
I have coolant leaking from the bottom of the thermostat housing around the water pump supply tube. What is required to remedy this?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Sure it isnt the small hose under the thermostat?
if it is the pipe to the thermostat housing it is just a O-ring
dh737
Jan 26, 2009
3
possitive it isn't the hose, coming down the pipe from under the thermastat housing. Any tricks to changing the O ring?
super diesel
<<<< Under Pressure
I remove the upper fan shroud and the fan assembly (be sure to unhook the crank sensor wires before trying to pull it out). You will have access to it then. Replace the little cross hose that's connected to it when your in there with some good hose. These like to go at a very bad time. You will want to get some replacement 'O' rings for it (top and bottom). Use some good silicone grease on them if you have it before install. This greatly extends the life of them.
