Coolant issue
SteveLBZ06
Jan 6, 2013
200
Central MA
At work we have an lly with 190k miles, all stock but worked hard its whole life.
The low coolant light is on intermittently but I'd say most of the time. The hose is hard most times but not 100%. Last winter it blew coolant out the overflow everytime I'd fill it due to the low coolant message but this winter it doesn't seem to blow it out but the coolant still disappears. If you open the reservoir it has lots of pressure and will blow out coolant. There is no noticable smoke or smell at exhaust. It also blows small bubbles into the overflow tank.
Truck does not overheat or run hot even towing in summer if low coolant message comes up. Thermostats were changed last year with no effect. We've tried bleeding it through the bolt on top of the tstat housing multiple times and it flows solid coolant through there.
The most annoying part, being a plow truck, is it won't make heat unless driving or revving the engine. It will get to operating temp and a few minutes after stopping and idling heat gets cold and temp comes down. As soon as you drive it again the heat comes right back.
So is this the inevitable head gasket or could it be something more simple I'm over looking?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Head gaskets. No doubt about it.....
custom8726
2,784
Upstate N.Y
Head gaskets! Not a fun job!,
SteveLBZ06
Jan 6, 2013
200
Central MA
Yeah, I've been thinking that was the case. Truck still runs great and technically it's already been replaced in the fleet with a 15.5 ltz so I guess we'll just ride her out at this point. Was just thinking with most of its issues being intermittent maybe there was a glimmer of hope it was something else
chandler583
F'in New Guy
Dec 30, 2014
Houston, TX
That sounds exactly like the symptoms mine had, minus the part about blowing coolant out. My coolant wouldn't disappear, but air bubbles would collect around the sensor causing the DTC to set off the low coolant message.
