Well heres the situation, few weeks ago low coolant light came on, added coolant, no problem. Checked it about a week later and it was low, not low enough to enable the light. so i added. Well i ended up adding a little bit more yesterday. So from the research i've been doing, I don't have hard coolant hoses, i am not holding pressure in the overflow a day later, i am not puking coolant, i don't see visible leaks on the ground, i don't smell any coolant, from engine, cab, or exhaust. No smoke. I checked oil yesterday, not milky, seemed fine. Pulled oil fill cap and there was condensation, so i tested it. Indeed it was sweet tasting. What are some possibilities? I was thinking seals on water pump? Someone had mentioned cracked heads? Any help would be great.
This is my first diesel and i have only had it for about a month.
