Question: converting to a 6 speed
maxpwr69
Learning
Jul 8, 2009
103
Rapid city South Dakota
So should i just go with the suncoast upgrade? I'm a serious newbie at all this. Really haven't done a lot of upgrades on the truck. Just the Edge, but i want to get rid of that for the EFI. I've had the truck for 4 years and it's almost paid off..... Time to get a loan of a different type :thumb:
paint94979
Beer Nazi
Sep 18, 2006
11,715
Call Mike L he will answer any and all of your questions and help you out with buy a kit
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I agree it is not worth it, and hauling the 6 speeds don't typically get any better mileage than the 5s and when T/H is engaged 6th is locked out anyway. If you drive an empty truck 5000 miles a month then maybe but it would still take a while to pay for itself.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
you can tune around having to engage T/H for towing heavy loads. i got much better mileage when my 6 sp was working.....havent been able to run it in a year and a half almost. I would say don't bother with it yet....but ask Mike L what he thinks. you could also swap to 3.42 gears
jc1843
Sep 27, 2009
228
86
So Calf
I have the conversion from Mike L, and the only real benefit is the 300+ lower RPM while traveling on the road. Less engine noise, and maybe a little bit better MPG. If you have oversize tires, your mileage may even go lower because the RPM will be out of the "Sweet Spot".
Jun 28, 2007
3,259
NE Pa
I don't know about a converted 6 speed but my truck shifts into 6th when in tow haul. Had to run to the store and just checked it out to be sure.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
The 06+ 6sp do. But in the SC kit a new TCM is supplied, it is programmed to lock out 6th in t/h.
