converting to 1 battery
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Would a guy just pull the second battery and make a connector for the 2 cables to hook together and complete circut like if battery was there?
or
How does one go about converting to one battery.
I'd also kinda want to be able to throw it back in somewhat easy if I go to a cold climate vacation.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
We just did it on my buddies truck and we put a single red top optima and removes the passenger side batttery. Removed the ground cable completely and covered and taped up the positive cable as you cant remove that one. His truck starts fine in the NC climate and I am sure yours is similar
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Would a guy just pull the second battery and make a connector for the 2 cables to hook together and complete circut like if battery.
do that and you'll set off some serious fireworks. :eek:
just disconnect the 2nd battery terminals and tape them up separately...
slowlmm
Mar 2, 2008
2,582
46
so cal
are trucks has that nice conection block mike on the pasanger side you can just unbolt all the cables. then theres nothing left over. and it will be nice an clean that way :)
