Converting 01 2WD - 4WD..
RiPPeN
Oct 14, 2009
23
Calgary AB Canada
Was curious what all I would need to replace if I could find another 01-02 donor truck with all necessary diffs, cv-joints, t-case, drive shaft,etc..
Would the wiring for the electronic 4x4 buttons be behind the dash, as well as the ones going to the T-case or would I have to swap the entire harnesses? Am I able to just swap the rear tail housings on the transmission for the T-case or would it be easier to swap the whole transmission?
Has anyone done this before with much luck?
