Any one know what would cause a new converter to not unlock in a freshly built trans?
NJ_LLY Back in action Nov 4, 2008 560 0 0 Browns Mills, NJ May 30, 2013 #1 Any one know what would cause a new converter to not unlock in a freshly built trans?
pornstar dancin pornstar dancin Oct 23, 2012 251 0 16 almond ny May 30, 2013 #2 I had a similar problem and mine was caused by a bad ground. I would start with something simple like that.
Mike L. Got Sheep? Staff member Vendor/Sponsor Aug 12, 2006 15,681 232 63 Fullerton CA May 30, 2013 #3 What brand converter?
rgullett83 Active member Oct 27, 2008 1,607 0 36 Illinois May 30, 2013 #4 I have also had problems with the tcc valve hanging in its bore Sent from my GT-I9300
Mike L. Got Sheep? Staff member Vendor/Sponsor Aug 12, 2006 15,681 232 63 Fullerton CA May 30, 2013 #5 How free was the converter flow valve in its bore?
kjp800 - Aug 6, 2008 525 0 0 New Jersey May 30, 2013 #6 Converter flow valve is brand new and moves in and out with ease. However it is not a stock valve. Valve body was changed out with a known good one as well with no change.
Evan@InglewoodTrans yerp Vendor/Sponsor Aug 5, 2010 3,118 65 48 40 Western MA May 30, 2013 #7 For the two seconds it takes i would try unplugging the main harness to eliminate something electrical causing it.
Evan@InglewoodTrans yerp Vendor/Sponsor Aug 5, 2010 3,118 65 48 40 Western MA Jun 2, 2013 #8 So what was the issue?
