I know there has been some nice devices created to lock and unlock "on demand", and there are different parameters being looked at to control it, but what if someone wanted a K.I.S.S. unlock box?
I know for a fact when you hit the brakes, the converter will unlock (or otherwise it could be very dangerous). Does it get the signal from the brake pedal switch under the dash? If so, I assume it's a NO or NC switch and when the pedal touches it it either opens/closes the circuit. Could an auxillary switch be hooked up to provide the same function at the push of a button or flip of a switch FOR COMPETITION USE ONLY?
Or even slightly depress the brake pedal enough to light the brake lights but not apply brake pressure.....although I'm assuming a aux switch would be safer if bouncing?
