Converter clutch
Mike L.
15,681
232
Fullerton CA
What do you guys see here? It was noisey. I looked at 4 of them all the same. Going in for rebuild. This one had 20K miles.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
I'm no tranny guy so my wording my not be correct. It looks like the tabs are wearing alot and now has excess play?? Which would make for a noisy converter? If thats true what kind of material are those made of to be beat up so fast?
durallymax
Apr 26, 2008
2,756
Under The Hood
x3 on pretty purple.
Those big square teeth are the best out there because they never wear just open up any DP magazine and you will see the full page ad about it.
Mike L.
15,681
232
Fullerton CA
I did not mean to pick on a company with this. I will be showing pictures of other brands as I get them.
Fingers
Village Idiot
1,717
96
White Oak, PA
Unless there are matching marks in the converter housing, those are manufacturing defects.
As I understand it, and from what I have seen, these plates are laser cut. Poor laser parameter setup will burn the metal at the end of a notch cut. I've done it myself on some of my own parts.
I also doubt they have any significant impact on the clutch performance.
On Edit:
I just re-examined the first picture. The sample on the right looks punch cut/notched, not laser. I can't tell from the second picture. Bad notching operation cleaned up with a grinder?
MaxPF
JAFAWAM
Jan 12, 2011
182
Mesa, AZ
On Edit:
I was thinking the same thing as far as being laser cut. Only impact I can see is the extra clearance would allow the disks to rotate back and forth more as they engage/disengage, which might start beating up the teeth. :dontknow:
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
I dont know if this applies to these clutches but with road race and mx bikes when the clutch plate lugs get that worn there is a noticeable difference in actuation and performance. Seems like chatter and vibration and even dragging would be some issues here???
