Congrats to Buck Sprull , 6.05 1/8 mile
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
At the OBX race , the finals , it was Buck VS TS and it came in at TS = 6.06 Buck a 6.05 but TS got the tree and took home the win , Either way that is an awesome pass and as far as i know was fuel only , heard he tried to spray it but the juice didnt work , even if it was spray that is an awesome pass and def shows that the Dmax's are coming out strong this year and are a force to be reconded with :rockon:Damn good to see the" N2O D-max" back out to the track too .
[YOUTUBE]DdBB14gIq7s[/YOUTUBE]
paint94979
Beer Nazi
Sep 18, 2006
11,715
wow 6.0x 1/8th that is amazing... it does look like Bucks truck was spraying but once you go all out who cares :D
TrentNell
Jul 7, 2008
7,543
slc tuah
He sporting twins now isn't he?? What was his mph??
Ya Nathan Built him a monster set :cool2: , dont know on bucks but Caged Fury went 117 mph , damn now i have get another 5 mph out of my beast , a dmax has to beat Dennis this year , I dont care which one as long as it happens :D
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
I'm sure one of you guys can get it done!!:D
TrentNell
Jul 7, 2008
7,543
slc tuah
Where's maxed out? Not hardly a peep outta them yet this year?
Congrats on a killer race! Just wish the max could won.
Max'd out ran a 9.70 a few weeks back while testing in Boise , but lost a turbo do to a simple bracket coming loose ans sucking the intake into the second turbo ,turbo fragments then went through it taking out the top turbo at the same time and it took out the motor , so they couldn't make it :(
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
I think cage fury is going to be hard to beat this year, they have it running good, and pretty consistant, but definatly good to see the dmaxes coming out swinging.
MattZ71
124
Western Ky.
im sure it will happen! you, maxed out, or when dimitri gets the reg cab going, or any other prostreet dmax going will be giving them run for there money
dennis has that clutch/automatic trans deal in caged furry which helps them alot and u can see how much boost there leaving off the line with!
J Spruill
bringer of truth
Mar 30, 2008
770
im not sure what happened,i posted in detail but when i hit enter,i endedup viewing another thread than the one i was posting in. runs were fuel only. more will be posted later ive got to spend some time with the fam...
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Will be nice when Jess can get back on and post all the details. Video looks like he might not have been exactly where he wanted with the turbos. May not have been exactly on top of them and he was definitely a touch late on the tree. The TS truck looks strong, wished the Smith truck and Gabby would have been there, all of those trucks are really strong.
Yes we have two hurt motors, one was because we sucked the big turbo intake spacer through both of them and then the motor. Not sure on the other one other than we hydro locked it and got at least one rod, not exactly sure what was done, but it's doesn't have the correct protrusion, in fact it doesn't have any.:D Will post up when we know. First engine needs new cam, lifters and main bearings. Should be running by end of this week. Better be or we can't make Indy.
I'm not sure if any quick dmax with get a chance to run TS this year with the exception of Buck. I don't think Dennis plans on competiting in any of the NHRDA or NADM events. Only the outlaw series and some local stuff in Bowling Green. Maybe he will change his mind.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Obx
Buck run a awsome race but his light wasn't bad, It just looked bad next to a .001 LIGHT!!!! I was figured Buck would win because of the tree. Caged has a lot going on inside and Craig is a bad dude to cut a light like he did. Awsome race is a understatment! It made the trip worth going, even not racing and just watching. It also helps when Matt run a best with a 6.59 at 108. On drag radials with the same setup as the DPC with the weight out. We should have pulled everything out there to open the gap a little more. Jeff
Subman
Old Geezer
Jun 27, 2008
3,233
80
Jeff did you race your truck? Also were there any rails there and what was the fastest time recorded for the event? Thanks. Ken
