Confussed LMM
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
my 2008 lmm has simple stuff done my overall work truck egr delete 4" exhaust turbo back trans go efi live tune. ok before i installed the lift pump i was able to hit 18mpg easy now i cant hit 14mpg same tune same everything confused:confused: can someone explain this bc i am heading to Texas tomorrow night from ct and would love to get 18 rather than 14 lol and if anyone has a better mpg tune that they would like to share i will reply with feedback for you np. tune is a 500hp approx been on the truck sense new.:thumb:
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
If all you changed was a lift pump, you need to make sure you don't have a fuel leak somewhere.
Is the MPG showing 14 in the DTC or hand calculated?
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Do you know how much fuel pressure you have? I've been seeing a lot of air dogs being to high from factory
Mpsoldier
That just happened!
Mar 10, 2010
646
In my House
i will no leaks first thing i checked and running 12psi 150gph pump just weird never seen it before tank 222 going to try that next also waiting to do back to back sence its going to be like 4 fill ups
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I don't suggest just unplugging it. That's more Crap the cp3 has to suck fuel threw. Witch won't help. I personally don't think the ad is the issue.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
What type of EGR delete do you have? I would be pressurising the charge air system and checking for boost leaks caused by your EGR delete. We've also been seeing LMMs and LBZs lately with the EGR valves stuck open and they get bad mileage from it.
