compressor/turbine housing sizes...
723
i have notice that there at least 2 common ways to classify a charger.
1. exducer on the compresser wheel ie GT4088, 4094....
2. inducer on the compressor wheel. 64, 66, 70, 80....
for the most part i have this figured out
the other half is turbine housings.which im still fuzzy when comparing turbos spec
1 is done by Area to radius. nubers like .85, .95. 1.06.....
like this.. smaller the number faster it spools
the inlet (or, for compressor housings, the discharge) cross-sectional area divided by the radius from the turbo centerline to the centroid of that area
2. CM 12cm, 16cm....
all i know is the smaller the number the faster it spools... but what i dont know is how to get a common denominator to compare the two.
ie 4088gt (63.7mm wheel) compared to a 64mm turbo that i see alot of CTD guys running. the part that i dont get is how do i compare to how a 12cm, 14cm, 16cm that i normally see on a HX, Turbonectics turbo...
basic question
what does the "14CM" measure and how..
and the turbine housing is a giving copout answer.......
723
i forogt about this thread :rofl:
so i have learn some thing since then..
as i understand it.
AR is said as a % of the radius ex. area is .9% of the radia
XXcm is the area itself. would be the radius
now i just confused myself :rolleyes:
