symptoms of truck. start a little hard, one cylinder was farting, popping and going in an out until warm. idle fine after warm, no smoke or nothing. rev up truck to 1800-2500 rpms....truck would start to produce a blue type of smoke and had a little vibration that was not normal. I shut off number 8 injector, no more blue smoke and still have the same vibration and very minimal change in engine sound.
Before i started the truck engine was reading 35 degrees
cylinder 1- 400
cylinder 2- 400
cylinder 3 -400
cylinder 4- 400
cylinder 5 -400
cylinder 6- 400
cylinder 7- 390
cylinder 8- 375
Warm with engine temp at 161 degrees. cylinders 1-7 ranged from 430-450 and number 8 measured at 400. I tested first bump on 6 and it first bumped to 225, then retested 8 with a first bump of 200.
Very good note to you guys, again i broke glow plug off in number 8 before, i had to drill out the plug and long story short i screwed up the head so ended up drilling a bigger whole to fit a 1/4inch pipe plug in it. So to properly get it sealed and what not i had to use a 1/4" air fitting and install a small port into the fitting to hook my pressure gauge to it. So number 8 is reading so different because of the space that is open that the glow plug usually plugs up, i was pretty much getting a compression reading with it piped off with the fitting out side of the head, so i am certain the cylinder is still good to go.
