Compound setup
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
Ok I have a question for yall. Im looking to put a s475/stock setup on my truck (lb7). Im trying to build my truck in stepping stones, so im wondering if I get that setup, what turbo can I put in the valley later on when I need more air? Or will I have to ditch the whole 475 over stock setup. I was thinking a 480 over stock because I think you can put a 366 in the valley, but I haven't seen a 480/stock setup for a lb7. I was looking at getting the setup from Jason at wehrli fabrication. What do yall recommend?
dirtylb7
slowly but in the process
Oct 29, 2010
utah
My buddy has an lb7 that had a 475 over his stock turbo truck ran amazing he drove it for a few months and then I put a 480 on it over his stock turbo truck ran twice as good the 480 pulls a lot harder up top vs 475. Correct me if I'm wrong but I think the s480 is the biggest you will want to go with on a stock motor.
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
That's what I was thinking about doing. Im not worried about blowing up the motor because when I happens its a perfect excuse to make it what I want :roflmao:
dirtylb7
Oct 29, 2010
utah
I'm not 100% but I think the piping would be different, they don't have the same heights or sizes but I would talk to Jason, very knowledgable guy!__________________
Piping is the same.
dirtylb7
Oct 29, 2010
utah
What would you put with the s366? A s480? or are there a lot of different options?
There are several different options. 66/480 is a pretty common set up on these trucks really depends on what your plans are with the truck. That same buddy built his motor and is running 66/483 put down 800 rwhp on his break in tune .
cafryer
May 5, 2011
1,074
Utah
Piping is very different between an IHI and a s366. The s366 has a v band discharge flange and a 4" hose intake. The IHI has a bolt style discharge and it has a bolt style intake.
5,836
What kind of hp are you aiming for? I've got a 475 over a reworked stocker right now that I'm pushing pretty hard. Track times show it right around 750hp. This week or next I'm swapping a 480 wheel and cover on the big charger.
dieseladdiction23
Nov 13, 2012
152
Celina, Tx
Its probably best I don't say what horsepower im going for, ive seen how that ends :roflmao:, But no its working it way to be just a race truck, but im just building it slowly, 1 because I don't have the money to put it all together at once, and 2 its my hobby that I enjoy so I like to gradually go up. Im really looking for around 850 to 900. But obvisously not till I build my motor. so what do I need for a good base setup that I can build off of
9,903
149
You can get a V-Band to hose adapter though if one was to need such a thing. The other cover for my S464 is going to get that when I sell it. If I had new about it when I first installed the 464 I never would have cut the one off my old turbo and needed to buy a second cover.
