I forgot about the time slip and just found mine. I went 1.136 60' 3.083 330' 4.716 1/8 at 150.88 6.168 at 1000' 7.640 at 142.93 lifting at around 1000'. Greg's slip is bogus. Also looking at Scheid's time slip he went 1.194 60' 3.127 330' 4.582 at 170.43 1/8 mile 5.819 1000' and 6.862 at 215.34 1/4. Scheid normally runs quicker in the first part of the track. He has run 4.30'sand I think high 20's in the 1/8 mile. Greg smoked the lights or body drug the beams or something. His numbers don't add up and I would have to say that's why he didn't produce another time slip close to the one he posted.
I am answering the questions only for the many people that are supporting me on here. as on other forums a few try to establish what the rest should think.
First this is not some Podunk event , but a NHRA divisional event where Guard beams are in effect Smoking the lights , where the motor is 20 feet from the beams. are you that dumb. the same is true for dragging the body. You roll 6 inches forward with out releasing the start beam and you bring on the red light.
I have more power then you Jeff plain and simply and a much better purpose built car , that is 200 to 300 lbs. lighter .
The motor let go 3.98 seconds in to the run . I dropped the nitrous and had oil pressure and continued the pass
