Ok so im having some problems with my fuel system. Im trying to command 160mpa but when i command and log try to log it the log shows im only commanding 38mpa max? am i not leaving it at 160mpa long enough for the log to pick it up in a freeze frame? Or is my Cp3 really weak? i only leave it at 160mpa for like 5 seconds bc the truck sounds like its about to blow up. I know my FPR is bad but would this have anyhting to do with not getting the desired rail pressure? thanks in advance for the help
