This what I was thinking but doesn't it need to be able to pivot?That's a bunch of weight for a needle bearing, can you get away with a steel shim instead?
Set up just like yours I believe.You have a pic of how you have your bottom setup? Only reason I can see is if there is any slop in the mounting bolt.
are yours still holding up?
