If you are running stock height or just level, you may need something else to prevent them from hitting. I can't remember the names of the parts, but call Nick and he'll know what you may need. IIRC it's the sway bar end links that also should be done when replacing with Cognito HD tie rods. You can find more info on DP or someone here may have seen the info too.
