1300 miles on a rebuild for transmission and transfer case (due to pump rub). Replaced the ATF in my transfer case with Mobil 5/30 synthetic, hour later trans limped. Throwing C0055, P0842, P0847. Replaced spin on filter and reset codes. Limpes after trans is warmed up, runs ok when first starting (cold).
Any Ideas? Removed programer and running stock, still limps. Rebuild guy no longer returning my calls. I thinkg the Mobil 1 change has nothing to due with my current issues, but would like to hear from others if someone has had the same problem.
