Codes PO 0090/U1800
jojo
Dec 12, 2013
65
Southern California
Codes will not clear/erase.
Has the computer or FICM failed?
Background: code PO 0090 had tripped and Truck would not start until code was cleared. Code PO 0090 would not clear after multiple attempts to clear and U1800 appeared on scanner.
I replaced cp3. Code will not clear
aashton1206
172
New fpr
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
5,911
you need to check the wiring to the FPR, ohm it, check for voltage, etc. then test the FPR. you keep clearing the computers is probably causing the u1800
jojo
Dec 12, 2013
65
Southern California
Sorry for not getting back to this sooner. Got busy with life.
Multimeter reads very little out of FPR output. 0.04, at best. Is there a fuse or relay that can be checked? I'm under the hood right now.
aashton1206
172
I pmed you giving an explanation
3,729
297
Why not post the explanation here where it can help others in the future? Not like there are any trade secrets around diagnosing a FPR.
Sent from my S60 using Tapatalk
aashton1206
172
Because we are in the secret itstheecmclubandyounotinvited club. Jojo needs a new ecm to regulate the few fpr.
