Code PO128 Coolant Thermostat Performance
Supermoto68
Jan 17, 2021
27
I keep having this code pop up over and over, does it have to do with my tuner ? Any help would be appreciated
2,205
Does your engine seem to be running cool or taking a while to come up to temp?
More then likely it is bad thermostats or temp sensor
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
If you Google it, people have copy pasted the diagnostic instructions into a reply on other forums.
If you find the thermostats are good and ect sensor is accurate, you end up testing circuits. Any resistance will make the sensor report a lower temp than actual, which the ecm sets p0128 for.
Sent from my SM-G960U1 using Tapatalk
Reactions: Bdsankey
Supermoto68
Jan 17, 2021
27
I have been watching my temp in my truck an it seems to be running around 185 degrees all the time. Is this below normal as my truck keeps setting off this sensor every few days.
