Code P1294 Help
BIGX
Toxic Customs
Oct 5, 2011
15
Alberta, Canada
P1294 Code. Injector connections are good, and have tried different FICM. Checked all wiring associated with ficm and ecm. Tried another ecm. Injectors resistance all measure ok. Truck has a new engine and compression is good. Truck idles with a lope but not fuel pressure related. Truck runs perfect when accelerating and loaded. Injectors 1,2 and 7 Always have different pulse at idle than the rest. Can injectors cause this code even if the resistance is ok? Anyone run into this and find a fix?
