This is the second time I've had this code. The first time I used the info from this website to replace the relays (including the glow plug relay also when it went). Rather than pay the $168 for the entire controller, I put in 70 Amp relays as suggested. Nearly 2 years later, it has happened again. For $13 a relay, I can keep replacing them for many years before I've spent the $168 so all is well. However, when I replaced them before, I saw they were packed with some sort of grease. Can anyone tell me what type of grease that is so that I can add it? Since the relays are in a very hot spot, I would think the grease mitigates the heat. I don't think it's a dielectric since it is in contact with the terminals. Anybody know??
Thanks
Doug
Thanks
Doug
