Code p0370
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I should have mentioned we did relocate the ficm to the inside of the passenger fender to get it off the motor.Wonder if 1 of the pins isnt tight.The bad thing is we extended the wires and im afraid it could be 1 of the conections then,dam that means lots of ohming out wires then :(
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Ok i will check that out tomorrow,We were geting a slight ground but we ran a jumper from the ecm and tryed that but still no engine rpm registers.
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Well the motor was pulled and everything unbolted to be powdercoated and replaced.I am using a differant ficm was only used to test a few engines,the bad thing is i never checked it after i got it to make sure it was ok.
We extended the ficm wireharness. added the duel fueler.I weird thing i didnt have before is a service airbag,not sure why thats on.Extended the batt cables on the passenger side to relocate the batt to the bed.
