my work truck is getting the p0094b code popping up on the scantool (small fuel leak). The truck is loosing power, 5 sec long cranking on startup (no external leaks and no fuel in crankcase). btw, the truck is a 01 lb7. Does this mean i need injectors, or cp3? scanner says it makes 23,000 rail psi.
