LB7: Clunk Letting Off Throttle
RobsDmax
832
Arthur, Ontario
On the highway if im cruising at 60 or 70 mph, and i go from a little throttle to letting off throttle completely i notice a small clunk and it only happens sometimes. Would this be the splines that need lubricating on these trucks? that comes from rear of transfer case?? Any ideas
02duramax
162
Yreka Ca
Drive the vehicle onto dual ramps or have the car raised to gain easier access to u joints.. Move the joint back and forth and up and down and see if there is a lot of play in the joints. If there is movement in the cross itself, replace that u joint. I had to replace the carrier bearing in the middle cause of vibration.. Was less than 50 bucks, Check it out..
bevi
Jan 17, 2010
709
Nh
It deffinatly sounds like something in the drive shaft makes since its under pressure when your in the throttel and when you let off that pressure releases.
bevi
Jan 17, 2010
709
Nh
wouldnt hurt to grease everything while your under their. just a thought
bevi
Jan 17, 2010
709
Nh
I just ment anything you can find with a grease fitting. It prob isnt anything to do with your clunk but you never know.:D
bevi
Jan 17, 2010
709
Nh
should have anything to worry about then just trying to cover some bases. Did you end up getting new rims i had asked a while ago about your h2s.
RobsDmax
832
Arthur, Ontario
ya me neither im not to worried but maybe u joints need replacing anyways. i haven't but the h2s are off. they still have tires. where are you from
bevi
Jan 17, 2010
709
Nh
i figured shipping would get me. Not really ohio its a ten hr ride on a good day. Its no big deal was trying to get something diffrent on for winter. Thanks tho
