shotgun cleaning kit
X2 that's what I use and it works great.
X3 with a drill on the other end. Talk about quick easy work. Used a long little flat head to the stubborn bits that wouldnt come off
If they stick bad to the injectors I would replace the cup. they are cheap and I had one that was stuck bad to the injector, I reused it then got to change the cup 600 miles laterThanks guys, pulled all but 2 with inj.!!!
Only had one that was, stuck on, ended up splitting it down the side to get it off!!!
