I was wondering how you guys check your balancing rates with a dsp5 switch installed? When I select the stock tune my rates are from -1 to +1 on all eight. If I go up further like 2 clicks I can hear a change in the motor and then the rates all go up and 2 will go to +4. The truck runs awsome and no reason to think anything is wrong. I was bored and was checking them. Before the dsp5 my rates were just like if it's set on the stock setting on my dsp5 with the big tune loaded. Do you check rates with the stock tune?
