LMM: check engine light w S&B intake
cdbright
JUST RENT IT
Dec 16, 2008
1,015
Salt Lake City, UT
after install i have a CEL, no flash tool, will i be ok till i get my DSP 5 tunes loaded, it wont go into limp mode ? i assume it is from the MAF mapping?
02greysixer
1,829
North Central FL
Try Unhooking batteries for 5-10 minutes. Or it may go off after enough key cycles. or go by an advance auto/AutoZone/oreillys parts store. Sometimes they'll clear cel if they're cool.
Tool958
Dec 30, 2010
Illinois
I would buy you a scan tool from Autozone or Oreilly's etc. They are fairly inexpensive and small I keep mine in the center console. I have used mine several times since the DSP 5 install. To give you an example, we left on a trip three weeks ago. Pulling the 5th wheel. Hadn't got 5 miles from home and it went into limp mode and wouldn't shift out of second. Put it on the scan tool and it showed error on 2nd gear ratio. I wasn't pulling hard or anything along that line. Cleared the code and haven't had a problem since. It was like it was confused between the ECM and the transmission module. The custom tunes are great, but at least on mine there have been little gremlins running loose every once in a while. Last year while out in Sturgis I used it to diagnose the MAF sensor went bad and bought a new one. Replaced it in about 5 minutes for the cost of the sensor. It's hard telling how much a shop would have charged especially out on the road.
shaedog81
Dec 2, 2011
11
Corona,Ca
I'll be in Irvine tomorrow if your in that area pm me and i can clear that code for you. I did some testing for S&B and could help you out with that issue.
cdbright
JUST RENT IT
Dec 16, 2008
1,015
Salt Lake City, UT
that is a good idea, what kind did you get and how much was it? and is there a better one to get ?
the code finally cleared after enough starts.
Thanks for the help gentleman. :thumb:
SoCalMike
760
SoCal
If you have a android smartphone you can down load torque pro for 5$. The get a Bluetooth obd scan tool for about 25$ from amazon.
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
3
Nowhere, KS
I had a similar issue with my S&B initially. I reset it several times with autocal. I then cleaned it with MAF sensor cleaner/cleared with autocal and it finally went away with the combination of those two. Some of the oiled filters can wreak havoc on the sensor. My :2cents:
15,681
That code will come back.
