Have some questions regarding a 2010 LMM Chassis cab truck i need to do some work on.
They want the DPF deleted, egr deleted, lift pump/pre-filter system installed (they have poor fuel) and a mild tune.
heres my questions.
On the exhaust system, I realize the chassis cabs are different and that Flo-Pro makes part number 851 which is a complete cat-back system. However i cannot find how complete it is. Does it still turn down in front of axle or do i need to order a seperate tip. Does it include a muffler. And as far as the front-pipe goes is it the same as non-chassis cab trucks meaning i could just use the front pipe from one of them or not?
Aside from that I am sure the EGR system is the same.
Did they detune the LMM Chassis Cabs or not?
And when it comes to an Air Dog system, they will not install the same on a chassis cab correct? As the fuel tanks are mounted differently? And what would be the proper way to plumb the system with the two tanks?
If I could have the truck in front of me to look at id have a lot fewer questions. But its 1.5 hours away. So i figured i'd see if anybody else had done much to chassis cabs and would have any answers or heads up.
Thanks.
heres my questions.
Thanks.
