Chasing a Ghost. Timing at idle.
08lmm72mm
537
168
Saskatchewan, Canada
Hey guys, I've been slowly fixing every issue on my truck trying to make it run like it used to. The problem I'm having is a persistent rough idle and sluggish throttle response with more than usual black smoke until the turbo lights. Even sometimes on my bigger tunes I get the odd pop or light backfire at 16-1800rpm getting heavy on the throttle.
Things I've changed:
FPR new bosch unit
New Harmonic balancer
Harmonic balancer dowel pin (bent)
Oil pump drive gear dowel pin (was bent)
Rebuilt Fuel filter head
Installed 1/2" CP3 inlet fitting
New 1/2" fuel hose to and from the fuel filter housing
Changed MAF
New MAP
Clean new dry filter
I've testing the CP3 with a tech 2 commanded rail pressure at the way up to 180mpa without issue. Can cycle the vanes in the turbo from 0 - 100% without issue. Installed fuel pressure gauge in bleeder screw on fuel filter housing confirmed 8psi from lift pump.
Balanced rates are:
Cyl1 0.9
Cyl2 -2.5
Cyl3 0.8
Cyl4 0.3
Cyl5 -0.3
Cyl6 -1.8
Cyl7 2.3
Cyl8 0.2
Calculated fuel rate bounces from 6-10mm3.
I'm at a total loss. Injectors have 100,000miles on them so does the turbo.
Main injection timing is 2 degrees at idle.
Possible my ecm is acting up? Zero boost leaks.
Going to check injector return rates next.
Any help is appreciated
08lmm72mm
537
168
I have a log here if someone wouldn't mind taking a look at and see if anything sticks out. I'm curious why my maf looks like it dips around frame 300 at WOT.
  • july07.zip
