Last week while on an adventure into the Big Horn Mountains of Wyoming with my trusty 02 Dmax towing my 11,500 5er with a 4 wheeler trailer tagging along, I hit a bad patch of snow/ice while climbing over a pass in the national forest and buried the truck in the snow, wishing I would have chained up prior (stuborn). So, I spooled out the 12k milemarker winch and wrapped the cable around a boulder and pulled myself to the center of the road where I could install my tire chains a little easier.
At that time, I noticed the voltmeter down in territory where it appeared to be discharging. It was getting dark and all the lights of the truck and trailer were on. I got the chains installed on the front axle and attempted to pull forward and managed to bury the front tires into the road base below the snow crust. Out came the winch cable again and this time when I went to power in, the lights went dim and the truck didn't move. The low charge light came on and now the transmission wouldn't go into any gears. UTOH. Luckily a guy in a dodge came along and since he couldn't get by, gave me a hand and even offered me a beer. I had him give me a jump and let the batteries charge for about 5 minutes. Gave the winch a try and the transmission was now working as well as the alternator. Out we came.
On Monday when I got back to work, I load tested the batteries, one only load tested to about 270, the other 370. The batteries are rated at 900 cranking amps and 700 cold cranking. They are 4 years old. While under the load test, the batteries both dropped to around 8 volts.
My biggest question is what made the alternator quit charging? I also tested the alternator and it put out 80+ amps @ idle after the load test.
The winch is rated to draw 370 amps at full load, and I have used electric winches for years and have had to wait on the altenators catching up, but have never had one quit charging. Any thoughts?
__________________
__________________
