changing gear ratios
DPC
323
Adams, TN
What would it take to change gear ratios in a 5 speed Allison? Make 3rd 1.81, 4th 1.20 and 5th .071 that way I could do a 3rd gear start and the allison would only need to shift two times. This would be for a drag truck.
DPC
323
Adams, TN
If it's not possible could you make an allison stay together with a 3rd gear start, stock ratios, if you had the HP to do it? Stock third is 1.41. Maybe a high stall with a manual lock-up?
When I used to pull often, 3rd and even 4th gear starts were very common, but in low transfer...
