Allison 5sp: changed convertor now getting codes
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
I had my sc 1053 2700 stall refreshed to a 3600 stall done by dpc. Now I am getting p0841,p0843,p0848,p0742 codes.Truck will run fine until codes come up and when they do truck will lose all the gears. Reset the codes and it will run fine for a number of cycles and them throw codes again. I am running a 4th gear start and a dhd lock up box.
15,681
The 800 codes are valve body codes. The 742 indicates the TCC won't release. 4th gear starts will put you at a very high stall. Can't imagine what will happen with possible 4K stall combination.
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
Never could get the turbo to light with the 2700 stall until 50 to 100 ft down the track even with 4th gear start. Guess i could go back to a 2nd gear start and see how that works. Only running a 75mm with a 87mm turbine and 1.28 housing.No problem spooling it as of right now
