Cat Fuel Filter to replace OEM
LBZoom
Apr 7, 2009
23
Hey guys,
Does anyone have the part number for the CAT filter that replaces the stock Delco? Thanks for the help!
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I think you have to have the adapter to fit another filter in the stock location
Sent from my ADR6400L using Tapatalk
RoboF16
True. Try Nicktane.
CAT 1R-0750 or 1R-0749 is the longer one you can use if you space the stock filter head away from the engine a little.
Colt
Jul 23, 2010
523
Eric Merchant sells the spacer block for the filter head. Can give advice if you need.
