Casper's Twins first dyno.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Took Casper to Westech Performance in Miraloma CA today to get some data on the PPE twins. These are intended for land speed racing, so the goal was to lower EGT's and extend the RPM range.
So I used a fairly small shot of pump diesel and ran it up to 4500rpm. It made 790rwhp at 4500rpm, and boost was still climbing. EGT's were 1450 deg peak with that fueling. The serpentine belt jumped the track, and the water (pure) injection was malfunctioning, so I cut the day short.
It is a good improvement from our Bonneville setup last year, but we are going to need 900rwhp @ 4500, and a little lower EGT's to go 200mph.
Certainly no dyno queen #'s, but I'm OK for now. We are going make some changes and try to optimize it a bit more. It runs very smooth on the street except for traction issues, and has good throttle response. We can add about 30% more fuel when the time comes.
This is just step one, and should be back again to Westech in the near future to dial it up a notch.
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
congrats those are good numbers for a custom setup's first run. i am sure with some tweaking you can hit you 900 mark :D goodluck this has been an awesome build
maine04max
Dec 11, 2008
1,009
Im just curious , but is the traction issue cuz power comes on to quick? Im not trying to be a smartazz .
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
Damn, wanting more than 790 hp ? ! :eek:
Thats a Damn strong engine for sure, I'll bet you'll easily make your goal.
Good luck! DMAX POWER!!
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
What I like about your trucks Pat is they perform on the street. I see some posting about dyno numbers they hit but it dosen't perform like it has those numbers. Casper has always ran great and your setup is always atleast from what I read about it on top of the game being land speed or drag racing. Congrats on the shake down numbers.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
congrats pat if you've got 30% more fuel left in reserves to give it later thats got to be a useable 900-1000 hp if egt's alow :D cant wait to see what he will do on the track once its dialled in .
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
took casper to westech performance in miraloma ca today to get some data on the ppe twins. These are intended for land speed racing, so the goal was to lower egt's and extend the rpm range.
So i used a fairly small shot of pump diesel and ran it up to 4500rpm. It made 790rwhp at 4500rpm, and boost was still climbing. Egt's were 1450 deg peak with that fueling. The serpentine belt jumped the track, and the water (pure) injection was malfunctioning, so i cut the day short.
It is a good improvement from our bonneville setup last year, but we are going to need 900rwhp @ 4500, and a little lower egt's to go 200mph.
Certainly no dyno queen #'s, but i'm ok for now. We are going make some changes and try to optimize it a bit more. It runs very smooth on the street except for traction issues, and has good throttle response. We can add about 30% more fuel when the time comes.
This is just step one, and should be back again to westech in the near future to dial it up a notch.
congrats- what was the boost at 4500 rpm, and wht was it still climbing to when you shut it down? Sorry for the caps
