I have a 2005 cc sb lly with belltech lowering shackles keys set to where the front sits a tad lower, 16x10 classic 2s with 285 toyos. I have a vibration driving me insane, basically at all speeds but 45 seems to be the worst. The steering also seems to be off a bit, not as tight as it usually is and at higher speeds it really gets loose. Year and a half ago I installed moog pitman and idler arm/bracket, moog tie rods, moog hubs, ball joints, sway bar bushings and links. The front end is basically rebuilt, a few months back i also installed blistein 5100s up front but i still have some cheap ranchos in the rear. The vibration is constant, but it gets real bad on any rough road, where the truck usually just has the one solid bump going over bumps or potholes its like it shakes over them if that makes any sense. A friend of mine said it feels like a bad shock but theyre nearly brand new? I thought i saw some play in the idler arm the other day so i pulled it off today and it looked pretty good, changed it anyways also installed a new steering stabilizer, it seemed to tighten up the steering a little but the vibration hasnt changed. Im tired of throwing parts at the truck, anybody ever had an issue like this?
