Cant open my tunes
jeramoosh
Sep 17, 2006
95
Harrisonville, PA.
My old laptop crashed, so i have another one that i moved all my tunes into but it wont open them, says Error cannot open tune file? The new laptop has windows vista, and i downloaded the new version of efi, and the drivers for vista, but thats the only difference from the old one. It will open 1 tune that was e-mailed to me but none of the ones i moved into it. Any thoughts on what the problem may be?
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
No idea really. I have vista and I couldn't get the download to work on mine and downloaded to a disc then installed the program from the disc.
Try run as (administrator?) I believe that is the option. Could try right clicking and then tell it to open, that is usually how I open mine.
Tune file layouts haven't changed between different versions of EFILive, so there should be physically nothing wrong with your files.
Now that yov'e installed V7.5.5, I'd suggest you check for software updates by clicking on Start->All Programs->EFILive->V7.5->Tools->Check for New Updates. The download on our web page will bring you up to build 72, the check for new updates process above will bring you up to build 77.
I'd suggest that your issue will lie around user privillages and that you need to setup your machine to run as administrator.
Cheers
Cindy
