Allison 5sp: Can't hold 4th (for dyno)
3,733
305
I tried to make a 4th gear hold tune for my trans (getting it dynoed today). It is set to hold 4th in tow/haul mode. However, it will still upshift and downshift. I can use the O/D lockout, but the downshift is the problem-- it keeps dropping to 3rd.
It hits the rollers in 1 hour, so I'll just try my luck with DVT for this pull, but I'd like to get this working for the "after" pull. Though after reading online, I am hearing that DVT may not hold it in gear either (plus I can't log at the same time).
Could someone look it over and let me know what I did wrong? Is there a certain OS that needs to be used?
  • TCM Dyno Tune.tun
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Ive never used a 5th gear lockout tune in a 5 speed.. I just start the dyno at the mph where it wont downshift to 3rd
3,733
305
That is what I'll do if DVT doesn't work.
Is it not possible to create a tune that holds 4th though? I'd think it should be possible...?
Sent from my Galaxy Nexus using Tapatalk 2
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Ive been able to log and use DVT's at the same time....?
That being said, the EFILive allison DVT's do glitch out half the time. If I dont really need to datalog, but I do want to make a dyno run, I just use the tech 2.
3,733
305
I remembered reading it didn't, and never tried. I'll give it a shot. That would be most convenient.
I wish I had a Tech 2. I should really save up and get one.
baggedLB7
Goer
May 1, 2011
688
Utah
When I did mine I was able to lock out 5th and then lug it down to about 1800-1900 rpm and lay into it with out it shifting down.
3,733
305
Was able to use DVT to hold 4th after all. Pulled from about 1500 RPM. I can use that again next time, but I am still curious if I did my trans tune wrong.
Anybody see anything wrong with it, or have a tune that's known to work?
