I just turned the key on my '06 LBZ and was greeted without a start. I manually pumped the primer, cranked, and repeated this about 10 times. The pump seemed to function normally, but after a few seconds of cranking the engine over, the primer went limp.
Is there a better way to prime the system? It was all apart, meaning the fuel rails were off, the fuel lines, etc. The engine was running good prior to the tear down, and injectors and glow plugs were not messed with. looking for advise on getting the beast started and what I'm doing wrong.
Tom
Tom
